Hey guys,
I have been stuck for several days trying to get my rover board to connect to my base station via RTK and could use some help from the group. I am fairly certain that I have configured the RTK2B board correctly and that I can see it enter a TIME mode after 120 seconds as anticipated, my guess is that my issue is in the XBee LR transferring and receiving of packets. I’ll try to go into as much detail as possible with what I have done up until this point so you all can see what I have already tried. To be clear, this isn’t an NTrip setup, I have a base station created with an RTK2B board with a XBee LR radio and a F9P GPS receiver, powered off a portable battery supply. On my AOG board I have an F9P GPS receiver and an another XBee LR radio.
To start, I can say that AOG is successfully transmitting data to the tablet. My auto steer, Ethernet, steering angle sensor, and F9P on the board are all functional and working correctly. I have tried update the firmware of the F(P with the AOGConfigOMatic program and using the included config file, however this yielded no results so ultimately I flashed back to just the updated firmware.
So far on the Base station I have connected the board to my laptop, opened UCenter and completed the following.
- Updated the firmware to 1.31
- Configured the board using the ArduSimpleRTK2B 1.32 Base config file
- In UBX-Config I have made the following changes
-TMODE3" Survey In, 120 seconds, 20 meters
-Ports
-Rates: 1000ms measurement time on all, 1 cycle nav rate
- Messages: UART1 & UART2 on RTCM 1005,1074,1077, 1084, 1094, 1097, 1127, & 1230
So far on the AOG F9P I have the following:
Fix Mode: 3D
In UBX-Config-Ports
I have made sure to hit send after each change and save config at each session
Outcome thus far
After 120 seconds Fix Mode on Ucenter switches from 3D/DGNSS to TIME/DGNSS
On RTK Board: Solid light for No RTK, flashing lights for GPS fix and GPS to XBEE
On AOG board F9P( indicator light continues to light red for no RTK, and main RTK indicator light is either out or red depending on different configurations of F9P on the board.
Let me know what you guys think I am missing!
