Trying to figure out why I can’t get RTK fix. I have the base and rover F9ps configured with 1.13. Teensy has the latest version loaded. Using AOG 6.2 I also need to know which mount point I need to use with Wiscors I know I’m connected to wiscors because I checked my account and shows which mount i used when I changed it.
When I first started out the tractor moved in reverse when I was going forward. I swapped the GPS antennas and the direction changed.
Also do I need a jumper by the radio header where it has RX3 F9P next to the teensy?
I reflashed the firmware to both F9Ps and reconfigured both and still no RTK fix.
I selected RTCM31 and got a RTK fix. Nowhere in the WIKI for Ntrip setup does it state which mount point to use. I’m still not sure RTCM31 is correct but seemed to work.
Can someone confirm I’m using the correct mount point.
Also I think F9P does not accept CMR type corrections. RTCM31 on the list works but only provides GPS + Glonass corrections. RTCM34 looks best for F9P.
