Not sure what the next step is. No signal to PC.
Just put my board together. Have power. Have antenna outside. Updated firmware and configured to rover on the f9p. Used teensy flasher to program -all in one for 4.x. . Not sure if that’s right as I’m getting no light on the teensy.
Not sure what my next steps are to get signal.
If your teensy is correctly receiving GPS, it will have a blinking orange LED on it. Try plugging the receiver into the AOG serial monitor, and see what NMEA sentences it’s putting out. It should be sending out GGA, and VTG, with numbers in between the commas.
Have you tried a different ethernet cable.
As said teensy should be blinking orange.
With what program did you configure f9p? And which file did you use as Rover configuration?
Edit: Guide here for U-center, but F9p can also be configured by flasher program.
configuring the zed f9p · AgOpenGPS-Official/Boards Wiki · GitHub.
When teensy is not blinking orange, then f9p speed might be wrong.
Next step would be to configure your computer LAN port to assign a static IP from what I see from your pictures.
Do you checked the YouTube videos?
training videos
