Novatel Smart7 Firmware update
I noticed that the Agco Novatel Smart7 GPS receiver has quite old software and decided to update it to this year’s software VER 7.09.05. I made a cable with a Com port, connected, updated, with Novatel Application Suite everything looked cool. Before updating, I did not save the receiver configuration. With the new software, Fendt “sees” the receiver, but there is an error 20.1.AA (it does not support this receiver or software). I loaded the old software back, but the same, it does not see. In the Fendt terminal, the receiver sees satellites, only the autonomous mode remained, without RTK.
Maybe someone has such a file with settings? Similar to this BMHR21341239N_2025-11-08_10-34-10.cfg
Or does anyone know which Com ports or baudrate or something else needs to be adjusted.
There is still time until spring :slight_smile:
However, the “Fendias” software was needed, and the NovAtel Application Suite software did not solve the problem. The dealer rewrote the tractor software and the receiver liked it. The error disappeared, the problem was solved. :+1:
