Hi
I have connected to the Ntrip caster at rtk2go.com - but I recieve no data.
When I press the “Get source table” the AGopen IO module frese / lock-up do not responed,
so I need to re-boot the PC to be able to run the program again.
Agopengps also lose the connection to the AGopen IO module
Best regards, Erik
Is your username a valid email address? Its also possible that you are banned from this ip, try connecting from different network.
http://www.rtk2go.com:2101/SNIP::STATUS
If this page doesnt open on web browser then you are banned.
Hi
I got the feedback below from rtk2go. They do not see that agopengps try to
obtain the data from the server. So the problem have to be inside agopengps I think …
Best regards, Erik
I see the base connecting and the two web page report requests, but I do not see any NTRIP Clients asking for it.
Your user account name (your email) looks fine, but please add ‘none’ as a password, some device are picking and simply will not connect without a password being entered.
But looking a bit closer, why does it say ‘Lovgaard’ there and not have ‘Tystofte’ used there?
I see users asking for that mountPt, but none with your email.
Regards,…
This is how my setup is for Ntrip - see pictures enclosed
email adress is valid and password is “none”
Hope this help …
On the last picture you have enabled TCP:port that should be off when you connect to a caster network
Thanks - after this change it works well …
