@KentStuff , I’ve spent the last several days using your version with the lines sorted by distance, and it is absolutely fantastic for how we farm. It would be awesome to see this in a future release, unless there is a reason some people would not like it. The only issue I had is the one pasted below. This happened when driving 2 miles around the section to get to the back side of a field, so maybe it was related to this?
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.get_Item(Int32 index)
at AgOpenGPS.CABCurve.GetCurrentCurveLine(vec3 pivot, vec3 steer) in C:\Users\Brad\Documents\AgOpenGPS-master(20210620)\AgOpenGPS-master\SourceCode\GPS\Classes\CABCurve.cs:line 381
at AgOpenGPS.FormGPS.UpdateFixPosition() in C:\Users\Brad\Documents\AgOpenGPS-master(20210620)\AgOpenGPS-master\SourceCode\GPS\Forms\Position.designer.cs:line 567
at AgOpenGPS.FormGPS.ReceiveFromAgIO(Byte[] data) in C:\Users\Brad\Documents\AgOpenGPS-master(20210620)\AgOpenGPS-master\SourceCode\GPS\Forms\UDPComm.Designer.cs:line 120
at AgOpenGPS.FormGPS.<>c__DisplayClass656_0.<ReceiveAppData>b__0() in C:\Users\Brad\Documents\AgOpenGPS-master(20210620)\AgOpenGPS-master\SourceCode\GPS\Forms\UDPComm.Designer.cs:line 306
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AgOpenGPS
Assembly Version: 5.1.7.0
Win32 Version: 5.1.7
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/AgOpenGPS.exe
Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK.GLControl
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/OpenTK.GLControl.DLL
OpenTK
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/OpenTK.DLL
Control.Draggable
Assembly Version: 1.0.7235.37687
Win32 Version: 1.0.7235.37687
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/Control.Draggable.DLL
RepeatButtonControl
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/RepeatButtonControl.DLL
Microsoft.GeneratedCode
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Windows.Forms.DataVisualization
Win32 Version: 4.8.4200.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Data
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Keypad
Assembly Version: 4.3.10.0
Win32 Version: 4.3.10.0
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/Keypad.DLL
ColorPicker
CodeBase: file:///C:/Users/sgfar/Downloads/AgOpenGPS_sort_Timer_curve/AgOpenGPS_v5/ColorPicker.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.```
