Ok so I’m thinking about ordering some AIO boards. The Wiki indicates that a 4 layer board should be detected. When I try to upload the Gerber, it always detects only a two layer board. What’s it supposed to be?
If you are uploading AiO v4+ STANDARD(edit) its okay than. AiO v2 was 4 layers(both micro and standard), maybe the tutorial is old for v2.
Ok thank you!
I am sure the 4.5 micro is still 4 layer but 4.5 std is 2 layer
Forggot to mention that, but he probbably tried standard version. Number of layers is stored in gerber file so im sure jlcpcb didn’t have anything to do with setting it to 2 layer pcb. Im I right @GVFarmer? You did try standard version?
Yes it was the standard version. Thanks again
