Hi,
someone I have been helping on getting there system going found something you could call a bug. Or like a lot of it guys would say it a feature.
When you make a ab line in the form of an ‘s’ or a ‘u’ it does create a lot of overlap.
With the u one you will even completly drive over the neighbouring lines.
This is because at this moment it just shifts te line a litle to the left or to the right. But when the line at some point makes a 90degree turn it will just end up in the same location.
This will result in a lot of overlap in some fields with curving ab lines that could be solved by doing a point to point translation instead of moving the line as a whole.
If this doesn’t belong here you can tell me.
If you want some more information please ask.
Kind regards and thanks for making an alreade awsome program.
