Pcb aio 2.4 doesn't work with modified cytron
Hi all,
I’m from Spain and I’m enjoying AGOPENGps for 2 years, first with a Kaupoi, then with Panda and now I’m trying to build an AIO 2.4 micro. The trouble is that it doesn’t work with the cytron modification. I’ve tryed with two different cytrons and both don’t work. It works with a regular cytron.
My question is: Is there “anything” to fix up on the PCB to make it work?
Thank you!
What have you tried and exactly what “doesn’t work” ?
It doesn’t move the motor, while with a non modified Cytron it moves it. I’ve check in the forum and I’ve found that this is maybe because a conection on the PCB must be cut and a 330 resistor might be added.
Its described here:
Thank you!!! I’ll try and then I’ll tell you
