PCB for a begginer
Hello, as the title says, i need help with a good and simple board that would help me to make my tractor drive itself. I don’t really know what pcb to use. I’m between PCB v2 and a Kaupoi 4.1. Wich one would work better for me? I need a simple solution.
I’m in eastern europe, so i can’t acces components very easy… So help
Thanks!
Hello, please take your time and wait for the upcoming all-in-one ( gps-imu-routing_Teensy4.1) version.
In the simple solution, you won’t have any problems with PCBv2 or Kaupoi, but the new all-in-one version can communicate with a single LAN cable and the processing speed is higher due to Teensy, in short, it achieves the imu and gps fusion thanks to the speed of the processor.
Hi Whiterose,
Do you have a timeline for the new board version? Thx
I don’t know because I’m not in the software group, but if you want to do it as soon as possible, I use the Jhmach card, all in one as a single gps, but the card actually works in dual. I will help you if you consider using this card.
