Finally got around to assembling my first PCB. Question on the DOG2, the ones that I recieved have a 4 pin terminal - is there a wiring diagram for these to tie into the PCB? I was just going to take the connector off. Thanks!
1- white 12 v
2- yellow gnd
3- brown X
4- green Y
I just chopped it off as well.
Dogs is a bit more money - but works very well
Perfect, that’s the one. Thanks heaps.
Where did you mount yours Brian?
very back of the tractor middle of the differential. A spot between the couplers. This put it solid on tractor, also right on the pivot point and low down.
I’ve just put mine right on the Autosteer box
If I was to do it again I’d probably try to find space inside the box
Just wondering is the cab somehow not a good place to put it?
Oh it is, but the ideal spot is as above
Ahh good because it sounds like a lot of work wiring it all the way down there
