PCB Wiring Confusion
What do all of these mean and where should i wire everything.
I am a complete noobie when it comes to electrical stuff so i have no idea what 5v high or low means, let alone the other stuff.
Thank you.
I am reading hundreds of pages every day, to program several projects.
thank you very much
Gameo is correct about high and low when concerning an input or output pin level on example a Nano. But in this specific case it refer to the way we can connect a WAS to the ads 1115. High is the normal signal input, and low would be used to connect the GND from an factory installed and powered WAS.
I already found it in another topic. My board is covered in a layer of dust.
I will limit myself to the code.
This was helpful. Only problem I was having is the alliexpress links are not in English.
What kind of browser do you use? I get Dutch as expected. Only PET is not a home animal.
