PCBV4.1 - build and test
That is what the lock valves do, so normal.
If you are asking how to stop autosteer, when trying to turn steering wheel, then check if your baraki valve blok is fitted with the pressure switch or the newer pressure sensor, and make the setting and wiring to use this possibility
