We are pleased to announce that our navisklep.pl has become a distributor of RAVEN hydraulic valves.
What are the benefits of this for you?
The blocks have road approval
CE certificate
24-month manufacturer’s warranty
Immediate shipping and availability without waiting
The valve will soon appear in our online store! Price list :
LS hydraulic block - PLN 5,500 net
Hydraulic block with OC attachment - PLN 7,800 net
The valvess have a flow capacity of 15 liters (they are enough for most tractors and agricultural machines, and the actual demand of the machine is lower)
Let me know what you think about them
Part of the profits from the sale of navisklep.pl is allocated to support the Agopengps project.
Working pressure
180 bars
Maximum pressure
210 bars
Maximum flow
15 l/min.
Recommended hydraulic oil
DIN51524
Recommended oil purity class
ISO 4406 or better
Oil temperature range
-30°C…+80°C
Ambient temperature range
-30°C…+50°C
Rated voltage
12V DC ± 10%
Resistance class
IP65
Duty cycle
100% ED
Seal material
NBR
Protective coating
anodizing
Internal threads: P,T,A,A1,B,B1
BSP 3/8
Internal threads: LS, pressure sensor
BSP 1/4
Connections (included): P,T,A,A1,B,B1
M18x1.5
Connections (included): LS
M14x1.5
A pressure sensor
ARGO HYTOS PSCG-1-250M-1 or GEMS 3200B0250S05E000
Output signal
current 4 - 20 mA
Sensor connection
4-pin M12x1 aviation connector
Measurement range
0 - 250 bars
Margin of error
0.25%
Sensor operating temperature
-40°C…+125°C
Sensor supply voltage
8-30V DC
Hydraulic proportional valve
ARGO HYTOS PRM2-063Y11/15-12E1K1-A
Hydraulic shut-off valve
ARGO HYTOS RPE3-062R31/01200E1/A
