Hello
When I connect. The ardusimple f9p has the Chuwi h10x tablet I wait for the beep beep but I do not see. No com port in device manager
On the other hand on another pc it is well recognized
hello
can be a windows update trouble
check this topic for example :
https://discourse.agopengps.com/t/com-ports-disappear-after-latest-windows-10-update-and-how-to-fix-it/6597?u=bricbric
thanks for the help
now new problem agio started? I do not understand
I have seen that question from AOG as well “Agio started?”
That happens when AOG can´t figure out your COM port selections.
So reopen Agio and connect to the correct COM ports, both for F9P and steer-module.
You might end up, having to shut down AOG and Agio via windows job-list if/when you choose wrong COM ports
EDIT: what port-speed do you use? try another speed (57600 or 115200)
after multiple tests everything works
thank you
a question: in agio the speed is 115200
what is the speed in the device manager (poert parameter)
To be honest I have nerver checked. But I suppose it would be best to set them at same speed.
