If that is the case (powering off everything) then I think my next port of call would be power cycling individual components. Probably starting with the F9P, and maybe leaving it off off a minute or two.
Or do you mean you are just restarting the tablet, or even just restarting AOG?
No I left tablet on and AOG running. Just steerbox and aio off. Also tried reset IMU while problems occured, that didnāt help. Now I have to find a way to power off F9P without powering off the bno⦠on the same pcb.
Of course I also tried to leave all components on and restart tablet and AOG. Thad didnāt help.
Random thought. Do you have a shielded cable on the WAS? With the drain setup properly (only attached at one end.
shielded cable, not drained I think⦠Never thought about this because the steering chart looks perfect. I will check this tomorrow and connect one end to chassis.
How did it go with this problem?
Im now having something similar, maybe worse⦠it worked fine for a year, now its very strange. Take a look at the video, im only moving str8 forward btw but it looks like it doesnāt know which direction
Edit: I just changed all the cables, new board, new IMU, reflashed firmwares, deleted agopengps in appdata, and started fresh⦠Works like a charm, but I still donāt know what was the problem.
