What do I need for a pressure switch to put in the load sense coming from the steering motor? I thought it would just be a pressure switch, but I noticed in the steer wizard you can set kick out as a percentage for the kick out switch. Are people using a pressure transducer, then adjusting the kick out percentage in agio to get it find tuned.
You can use either one. And then if you use a pressure switch, select “turn sensor”, set the counts to “1”. If you use a transducer, select “pressure turn sensor” and set at what pressure to disengage in the steer config.
Thank you
