Profiles
Good day I am new here and want to try AOG for the first time, I have already downloaded and install everything how ever I don’t have a GPS connected I wanted to try it on my laptop first before I invest in everything else, The issue I am running into is when I open/run AgIO it says the following: AgIO - No Profile Open Create or Open a Profile, I have checked the resources and cant find anything on how to Create a new profile I am running V6.8.5
Just create one by clicking the check mark button and follow directions
Yes I have done so however id didn’t seam to save it, I then closed AOG and re opened it and it asked the same question, After a couple of tries I tried the selecting the open and I found my profile, my bad sorry for that just a quick last one will I need to select a profile each time I open AOG? Thanks for the quick response
It will save and use the last one you used, it wont ask again to select a profile. However it can be changed if you wish.
Great thanks
