I’m working with SK21s rate app but I’m struggling to comprehend how it is to work together with AOG
In normal operation (haven’t got there yet)
-does it work without a switch box? (I don’t have one)
-is there settings in AOG manual vs auto sections that need specific settings?
-do I set the section pins in AGO and Rate app?
Specifically I’m trying to figure out how does RC control the sections. The instructions say to switch on MST switch. As soon as I do that that sections in AOG turn off and I can get them to turn on.
The control is: Switch>Section>Relay
The relays or equivalent need to be attached to a section. If the section is turned off/on with a switch or by pressing the section button in AOG then the relay will turn off/on.
