RC15 update issue
Updated to 4.3 with rate controller. For some reason it works, but instead of using the pin for section 1A it uses 1b. Same for the other relays. Also my auto switch no longer works on the switch box. But the others do. Is there a config setting I’m missing. Set on defaults for ESPRate. Not using flow control in this case but am concerned about those functions as well. Any help would be appreciated. Edit: I now see the switch box code has been updated but am not sure it will work since my switch box only has one auto switch.
Update: updated switch box .ino and auto switch works again. Deleted and reconfigured machine profiles but no change on 1A vs 1B pins issue.
