Hi, I’m finding my refresh rate very slow. It seems to update once per second.
Currently only using as a light bar type, no auto steer, no RTK yet (I haven’t had the need for it yet).
I read on another topic to check these settings, on ucenter which I have now changed.
Other than hitting send and save config, is there anything else I need to do as this has made no difference.
I have also read to try changing the baud rate, I’m not sure how to do this, if I change it in agio it stops receiving, do I have to do this via u center?
I have settled at 200ms (5hz) at the moment and it is working nicely for me. If i hit a bump it seems to change direction quite a bit. But I’m sure that’s another setting.
Thank you very much @wland, you have been very helpful
