Beta versions of v4 have been out and tried for a while - they have many errors which have been fixed in the release version. Absolutely stop using any v4 that is not v4.3.10
Run “Add or Remove Programs” In Windows Settings and uninstall AgOpenGPS.
Go to YourProfileName \AppData\Local\AgopenGPS and delete AgOpenGPS
Install new Version.
You must install the matching Arduino code, contained in the support folder
This version needs you to set everything based on the configuration you use, and make new environment, tool, and vehicle settings.
The wiki is being worked on, and i will be making some videos as soon as possible. Seeding has begun so i, like many farmers, will be busy for a while.
Lightbar works in a different direction than in previous versions
MMA (1D) must be set to minus to the right otherwise it works the other way around. I was struggling for a good hour before I realized that the lightbar goes crazy by setting MMA backwards.
Edit. MMA OK.
I haven’t managed to adjust the steering so that it stays on the line. Either I make a mistake or it doesn’t match my solenoid valves
i have same trouble even if i engaged or not the “keyboard” option
i put error message if it can help :See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.TypeLoadException: Could not load type ‘Keypad.ColorPickerControl’ from assembly ‘Keypad, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’.
at AgOpenGPS.FormColorPicker.InitializeComponent()
at AgOpenGPS.FormColorPicker…ctor(Form callingForm, Color _inColor) in C:\Users\Grizs\Desktop\SourceCode\GPS\Forms\Pickers\FormColorPicker.cs:line 24
at AgOpenGPS.FormGPS.stripSectionColor_Click(Object sender, EventArgs e) in C:\Users\Grizs\Desktop\SourceCode\GPS\Forms\FormGPS.cs:line 1165
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.StatusStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
The colour picker is a control in the keypad project - talk about misdirection. So why does it work on some computers but not others? That’s a puzzle!!!
Ok that works now, dont know why it wouldnt when I pulled into my ‘imaginary’ field!
Selection width box bottom left may have confused a little.
Thanks Brian, hope tractor time going well?
I’ve updated the release so it copies over Keypad.dll with the updated one - what a learning event as usual. this stuff gets me every time! Also in boundary when you click google earth the boundary form closes.
If you are getting an updated release of the same version - like i just put up for 4.3.10 just Add Remove Program in windows settings, then install the updated one, and all your settings will still be there.
Is it just me who can’t get 4.3.10 to work with pwm hydraulics and 6/2 valve, I use ibt2 and have a relay that pulls 6/2 valve which gets power from d4 together with “eng L + R” works with verse 4.1,
4.3.10 pulls and releases 6/2 valve so it becomes a very slow control, even with all settings of max.
