Has anyone. Has received an emay from rtk2go this morning saying this?
At this moment your GNSS Base Station ________ is having problems as it tries to connect
to the SNIP NTRIP Caster located at rtk2go.com:2101 (RTK2go).
You have been sent this automated email in the hope that the below details will allow you
to correct the problem. Below is the log entry from the last connection.
This has now occurred 100 times in the recent past, which triggered this email to you.
The IP address from which this connection came was: _____________
You may need to consult your last reservation eMail to confirm that the credentials are correct.
Connection Transcript Log:
Client [#C338584] appears to a Rev1 NTRIP Server connecting, Tue 07:24:41.699 AM (local), from___________
A remote NTRIP Server (was a Client) sent us: ====================== (74 chars)
SOURCE_____________
Source-Agent: NTRIP RTKLIB/2.4.3
STR:
=END= (an inbound PUSH-In data connection attempt using the Rev1 form)
NOTE: NTRIP Server #C338584 from IP:_____.034 Port:54100, mountPt [] rejected,
PUSH-In Connections are not being accepted at this time, at: 2023/08/22 07:24:41 AM
Please correct this as soon as possible to avoid having your IP address blocked by the Caster.
Regards, The Support team RTK2go
I have been using my base since January. Now it says mountp rejected ??
