rtkdata.online ntrip client settings
Hi all
I’ve set up a base station with Stefal RTKbase. I’ve made an account on rtkdata.online and i’m sending data from the base to the casting service. I can also see that there’s data received to the casting service on their webpage, so far so good.
The problem is that I can’t get the AoG NTRIP client to receive any data from rtkdata.online. I’ve seen that several here use rtkdata.online so i tought maybe you can give me some hints about what settings should be in the client.
passwords correct? case sensitive
on your rtkdata it should tell you all the log in credentials ,port, password etc
Double check the port. For me it’s 10637 even though it says in some places on their website it’s 2101.
Thats the thing tho, it doesn’t say what the client credentials should be just for the base.
Should the username and password be the same as to the website? I’ve tried a lot of different combinations but nothing seems to work.
For me my user name is my email, there is no password, and like I said before the port is 10637
Edit: I did some checking and it doesn’t look like it matters what you put in username. On agio I have my email and on ntrip checker I have my username from rtkdata and both work. They just show up as different username on the dashboard
broadcaster is rtkdata.online
put your mount point name in and then the port, typically 10123
im sure my username is blank
What receiver on rtkbase?
Mount name and his unique port number, that’s all what is needed.
Our station is: Mount: Kambbacken port: 10704
Broadcaster URL is rtkdata.online and that gives ip 82.146.60.24
I have tried with other mountpoints using rtkdata.online caster taken from the map also.
I try to use the client without user or password but still no connection. I can ping rtkdata.online just fine.
RTK2GO also works but ofcourse just RTK2GO stations.
Edit: Seems like i get a connection to the caster but then it gets stuck on “Authorizing”. Also if I click on the get source table button in the NTRIP settings i get a error message that says “Invalid IP:port” if change the port to 2101 i instead get a error message that says “No source data”
This really baffles me, cant understand whats could be wrong here
I tried logging onto your mount point and I get the same thing you do. It is also the same with the ones around you. I can log onto mine and ones surrounding me just fine. Have you ever had it working?
I tried to connect to one station in England - works, then i tried on in Sweden - also works. Then i tried our own station again and now it works too.
Ok I have no Idea whats happening vut lets keep fingers crossed that it keeps working.
The only other time i’ve seen it working was the first time that I tried to connect to it I saw on the rtkonline dashboard that there was one rover connected.
Thanks for your help everyone!
There was an issue yesterday with rtkdata.online
There’s a telegram group for this caster.
rtkdata.online doesn’t seem to like a username with an at sign (@) in it. I just enter in the tractor model number with no password.
You will need to use the correct port. Each stream has a unique port number (5 digits).
Any password or port 2101 that you see in rtkdata.online is for the connection between the base station and the caster. You do not use that password or port 2101 for the rover.
