New user here who hasn’t actually started using the software yet.
I just tried running AgOpenGps on a Windows 11 arm64 build, and it seems to work fine. Since this works I would think that running this on a Raspberry Pi and connecting it to an external touch screen i.e. 13.3" IPS Capacitive Touch HDMI LCD with Case (1920x1080)– The Pi Hut (just provided as an example. Have not checked whether it would be a good fit) would work as well?
What do you think about this solution? My main worries would be overheating of the RPi and perhaps also the screen, and wether the dust and shaking would be too much as well. As I haven’t tried out this system myself there are probably lots of other possible issues as well… hehe
But too me this seems like it could be a quite flexible and cheap way to get started. Buy a RPi 4 with 4Gb Ram for instance and a monitor that is suited. And if one of the components does not last too long it is quite easy to swap it out, or doing a upgrade as well.
Love it! The only way to answer these questions is be brave and try it out. I agree the Pi might get pretty warm but there are heatsinks etc you can attach and perhaps a small circulating fan.
If the Pi could also do the autosteer and the job of the external parts - it would be a winner.
Yes, would be cool to try and see. Do you have any thoughts when it comes to heatsink vs fan? I would think a fan would be better in general, but considering the environment with lots of dust I am not sure if it would do more harm than good?
Yes, that would be very nice indeed.
Took a quick check of cases
Would a case like this with the GPIO port on the side be beneficial in that case, or would it not really matter, or even be harder to use as one typically only connects to one and one pin?
since I’ve been involved with AgOpenGps, I’ve been asking myself the same question about Raspberry Pi and AgOpenGps. Unfortunately, I haven’t had the chance to test it myself yet. If anyone has already tested it, I would be happy to hear about any experiences. My research so far has been rather discouraging, as drivers can be a big problem, especially for touch displays (but this was in relation to Windows 10 on the PI).
I used to think some kind of ARM board and touch screen would be a great thing for AOG, and to a certain extent I still do. However a tablet has an advantage that you never have to worry about power management. Tablet is just on (and charging) all the time while you’re using it, it goes to sleep when you’re not using it. If need be you can manually shut it down. And of course take it with you easily from machine to machine.
With a computer board like the LattePanda or Raspberry Pi, you have to figure out how you want to power the thing, and how to shut it down. Commercial monitor units, for example, have full-time power, and then the keyed power acts as a signal to start it up and power it down. Even worse the Raspberry Pi has no power management features at all to my knowledge, so you can’t even suspend it to a low-power state. In fact with the Pi you can’t even power the board off from the OS (something you can do on a regular PC). I’m sure some kind of circuit could control the power to the Pi, and once the Pi signals that it’s finished the shutdown sequence, kill the power. Although I have no idea if that’s possible to do on Windows. The Pi is a neat little board, but there are better boards out there for this sort of thing, just on the power issue alone.
It’s good to know Windows 10 ARM can run AOG. I always thought Windows on ARM was limited to running software from the Microsoft Store, not unlike Windows S that’s on their x86 tablets.
i´m asking the same questions to me. Combineing a SBC with touchscreen. But i m scary about the many steps to go and all the part to buy first.
So my next step is to tryout a used Faytech Touch Panel PC. Something like this. 10″ Resistive Touch PC (N3350) - FT10N3350RES (faytech.us)
pros:
12V power input, no step-up modul needed
2 Ethernet conectors build in, no router is need to connect panda GPS and steering arduino via udp
heay solid case
possible to put in a 5g (4g) modul
It has been some time since I last looked into this, but I am now taking over the family farm, and will therefore probably try and setup agopengps on our tractor.
Will then try to look into this approach with a small single board computer to see if that could work.
@torriem it seemed like you had some knowledge around electronics (or at least SBC and power shutdown sequence etc ). Do you have any suggestions on a board that could be appropriate for this? Are there any new ones that have come out that could fit well here?
I know there are UPS hats for Raspberry Pi that add battery backup and can control power (turn on or off) from software. I don’t know how it would work from Windows.
I believe the Orange Pi 5 can also power itself off completely from within Linux. Not sure about getting it to power on from a signal (key on). Orange Pi 5 cannot run Windows though.
Also there are x86-based SBCs that can run Windows natively. For example, the LattePanda. All x86-boards have normal x86 power management, so power off from software, sleep, etc.
Dasung has introduced a 10.3" 60hz update e-ink screen (b&w only) that intrigues me. Is completely readable in bright sunlight, has sidelight for night.
The Dasung e-ink screen looks really cool! I guess there is not too much need for having color when running AOG. The color e-ink tech seems a bit slow and expensive to be viable at the moment… hehe.
I know this is an older post but….Raspberry Pi is definitely the way to go! You can get a Cana kit with a push button power cord for on and off! You can get a water cooled fan kit for cooling it’s really compact with the right case they have numerous hats for add ons already built lots of 3rd party companies design plug and play modules to run different things weather it’s gps module, cellular module, motor driver module the possibilities are endless I’ve made a touch screen full mini Bluetoothed keyboard cyber deck that’s smaller then a iPad that can do about anything by just adding modules that can be plugged into it and taken off again very easily
I’m glad you got your pi working, but i’ll be honest with you. In my experiece there are better single board computers than the Pi for running this system. I have built a pi version running windows, and the ARM processessor worked but generated a lot of heat and could get slow at times. My favorite single board so far to run it is a latte panda delta 3, especially with its built in arduino. it however is pretty expensive compared to a Pi. I have now been expermenting around with a GMTek single board computer, which are much cheaper. I just picked several up on prime day for under $100. They have been fantastic. faster than the pi, and have two HDMI’s for dual screens no hats required.
