Hello, first thread here.
I am importing a multi kml and when setting up the bounds for waterways I am not able to scroll past the 3rd one in the window to select drive thru.
If there are only 3, the lighter shaded part of the window is bounded on the bottom by dark gray, indicating that the list is done. When more than 3, the white extends to the bottom of the window, but no scroll bar.
Not sure if there isnsomething I should do differently?
I could join the waterway polygons outside of the field boundaries to reduce the number?
I was not able to find anything about this in the search.
