Hi guys if I wanted to just use 1 relay to switch on and off a 6 metre boomless nozzle, is there a way I can wire into the autosteer board with making a complete new machine/section control board. I’m using v5.6.14 Thanks
Yes you can just connect a relay to your auto steer board.
What auto steer board are you using & do you use UDP or USB?
Thanks Im using UDP with a nano autosteer board
Line 92 in the main autosteer page, just change the pin number to use a free pin.
Autosteer_UDP_v5_6_SectionMod.zip (69.5 KB)
Ok thanks
