I have tried many many times to down load a section sketch that I can get to work with AGIO. Every time it comes up with a new and more foreign error code. No such file or directory is common. Ive worked at getting it from down loads into a file with extract all but i must be missing a step. Ive looked for how to videos on downloading files from git hub but I have nothing. I understand this is a difficult question given I could be doing many steps wrong but is there a simple sketch that is somewhat fool proof ?
I don’t know any specifics about section control but put your errors into grok and it will tell you what they mean.
/ Improved ESP32 Section Control for AgOpenGPS - 8 sections
// Tested logic for PGN 239 Machine Data
#define VERSION "2.66"
const uint8_t relayPinArray[8] = {25, 26, 27, 32, 33, 13, 14, 16}; // IN1 to IN8
#define PinAogReady 2
#define AutoSwitch 17
#define ManuelSwitch 5
const uint8_t switchPinArray[8] = {25, 26, 27, 32, 33, 13, 14, 16};
bool relayIsActive = LOW; // Your relays turn ON at LOW (confirmed by blink test)
bool readyIsActive = HIGH;
uint8_t loopTime = 100;
uint32_t lastTime = 0;
uint8_t watchdogTimer = 50;
bool aogConnected = false;
uint8_t relayLo = 0; // sections 1-8 from AOG
void setup() {
Serial.begin(38400);
delay(200);
Serial.println("\n=== ESP32 8-Section Control v2.66 ===");
Serial.println("Relay pins: 25, 26, 27, 32, 33, 13, 14, 16");
for (int i = 0; i < 8; i++) {
pinMode(relayPinArray[i], OUTPUT);
digitalWrite(relayPinArray[i], !relayIsActive); // All OFF
pinMode(PinAogReady, OUTPUT);
digitalWrite(PinAogReady, !readyIsActive);
pinMode(AutoSwitch, INPUT_PULLUP);
pinMode(ManuelSwitch, INPUT_PULLUP);
for (int i = 0; i < 8; i++) pinMode(switchPinArray[i], INPUT_PULLUP);
Serial.println("Ready - Waiting for AgOpenGPS...");
void loop() {
if (millis() - lastTime >= loopTime) {
lastTime = millis();
watchdogTimer++;
if (watchdogTimer > 80) {
allRelaysOff();
if (aogConnected) {
Serial.println("AOG timeout - disconnected");
bool autoMode = !digitalRead(AutoSwitch);
if (autoMode && aogConnected) {
runAutoMode();
} else {
runManualMode();
sendBasicStatus();
parseAOGData();
// ====================== CORE FUNCTIONS ======================
void allRelaysOff() {
void runAutoMode() {
bool aogWantsSectionOn = bitRead(relayLo, i);
// If section switch is closed (LOW), follow AOG
if (digitalRead(switchPinArray[i]) == LOW) {
digitalWrite(relayPinArray[i], aogWantsSectionOn ? relayIsActive : !relayIsActive);
} else {
digitalWrite(relayPinArray[i], !relayIsActive); // force OFF
void runManualMode() {
if (digitalRead(ManuelSwitch) == LOW) { // Manual mode active
digitalWrite(relayPinArray[i], relayIsActive); // ON
} else {
} else {
allRelaysOff();
void sendBasicStatus() {
uint8_t packet[14] = {0x80, 0x81, 0x7B, 0xEA, 8, 1, 0, 0, 0, 0, 0, 0, 0, 0};
uint8_t sum = 0;
for (int i = 2; i < 13; i++) sum += packet[i];
packet[13] = sum;
Serial.write(packet, 14);
void parseAOGData() {
static uint8_t buffer[40];
static int count = 0;
while (Serial.available() > 0) {
uint8_t incoming = Serial.read();
if (count < 39) buffer[count++] = incoming;
// Look for header 0x80 0x81 0x7F (FromAOG) + PGN 0xEF (239)
if (count >= 14 && buffer[0] == 0x80 && buffer[1] == 0x81 && buffer[2] == 0x7F && buffer[3] == 0xEF) {
relayLo = buffer[9]; // SC1to8 byte is at position 9 in PGN 239
watchdogTimer = 0;
if (!aogConnected) {
aogConnected = true;
digitalWrite(PinAogReady, readyIsActive);
Serial.println("*** AOG CONNECTED - Receiving section commands ***");
// Debug: show what AOG is sending
Serial.print("Sections from AOG (binary): ");
for (int b = 7; b >= 0; b--) Serial.print(bitRead(relayLo, b));
Serial.println();
count = 0;
This is a better explanation of the code i was using. I can get the AGio to recognize the machine board but it never seems to send it a package it the esp can under stand. I have tested it with other code and the relay board functions as it should. Can anyone see why I would get communication from AgIo to the board ?
Is there a way to watch the serial monitor while being connected to AGIO ?
I don’t know from where you have this code but the parseAOGdata() doesn’t seems robust.
You have better ways if you look at the USB autosteer modules.
Maybe I read it the wrong way but it seems to me that your code will not recover if you miss some data.
For some reason i was not able to get MTZ code to work. I found a very simple sectional control and was able to get it to function properly. https://discourse.agopengps.com/uploads/short-url/c2K5JW6OpeRyqp7wHc5LjgBwyx.zip. I struggled getting the code to work. Handling downloaded files is not a strong suit of mine i seem to put them into files incorrectly and then it doesn’t like parts of the code being missing from the correct folder
