The fact that the tractor would remain pointing forwards even when reversing and the fact that you can fluently activate auto-steer when going forwards and then changing to driving backwards, sound like very attractive behaviour if it comes with the dual antenna approach.
I find AOG behaving very well with a single antenna (+brick + DOG2) when working normally, driving forwards but could consider dual antenna only for the two advantages mentioned above.
A pity AOG cannot achieve this with a single antenna. It is possible as our two commercial tools do it but perhaps it is too difficult to detect a sudden change from forward to reverse after a momentary zero speed and then glue the heading accordingly instead of rotating it 180 degrees. I assume this is very complicated to implement and/or comes with other disadvantages and leaves me happy to accept AOG as it is. Dual antenna always being a “not so expensive” solution. EDIT: I guess should have said “not so cheap” solution, single antenna always being the lowest cost option.
