Hi everyone. I am new here and in the gps. Few days i read here i dont find nothing about it. My question is does someone know how to or wanna help me set rtk on av map farmnavigator g7. I can took pic of all stuf i have and want add rtk with own base. On another tractor want build autosteer from zero. Thnx
Page 27 or 78 - use a local base at rtk2go etc, or set up your own as guided here: FreeRTK/README.md at main · lansalot/FreeRTK · GitHub
Thank you. But i dont have top end rtk reciever on rover. Have midle option with 30cm accuracy. I need new receiever? And on rtk2go i see nearest one 150km away is it ok?
I managed to get RTK on Farmnavigator G7
Here’s the recipe:
Baud Rate 115200
Mine had this config that I further altered:
GPGGA COM2 0.1
GPVTG COM2 0.1
GPRMC COM2 0.1
GPZDA COM2 1
GPGSV COM2 1
GPGSA COM2 1
GPGLL COM2 1
CONFIG NMEA0183 V31
SAVECONFIG
Receiver is the one we sell at AgOpen.shop (just make sure you add a note that you need RS232 version)
I used the built-in ntrip client over centipede. (not sure if NEAR works as I ended up using a direct base connection)
As a quick hack I simply used the USB connector on the back of the monitor to power everything.
