I have never used RTK level gps corrections before so could easily, once again, be doing something really dumb. When I click cliant ntrip and put in what I believe to be the broadcaster URL, I get this error. What did I miss? I also tried including https://
This is the document I am working with for reference.
IaRTNRTKProducts-NTRIP-QuickGuide (1).pdf (425.2 KB)
Any advise on which mount point is correct would be appreciated as well. I have no idea what I’m doing…
My firewall allowed apps list shows two instances of agio, not sure why that is but both are allowed so I don’t think that’s the problem.
maybe take the forward slash (/rtk) off the web address?
Just enter the IP in there 165.206.203.10
Then on mine I have to manual type in the mount name. I use RTCM3_IMAX. Also set your port to 10000
I do the same but am able to pick the mount name from the list when I click Get Source table. I use MSM_NEAR. Good to have another Iowan using AOG.
Do you mean MSM_IMAX or is there a MSM_NEAR as well? I’ve been meaning to try MSM_IMAX
There is a MSM_NEAR. Click the Get source table button and he list to pick from should pop up. You’ll have to have the ip set to 165.206.203.10.
@Justin8366 @B_bimmer @davidroberts30 Where are you guys at? I’m in Hampton 30 mi S of Mason City.
In kentucky you have to register sign up with the admin and get a password before you can connect. Not sure how your state works. If they have a contact give them a call
Runnells, IA just east of Des Moines.
I’m on the far east side by Dubuque. I was not able to enter just an IP, that field did not allow me to change anything. It’s like the current one is permanent. I can highlight it, but cannot delete it or type over it in any way. I was apparently stuck in some infinite loop due to putting it in wrong first.
After a fair amount of fiddling everything stopped complaining. Does the little words RTK fix with a colon after it in the upper right corner mean everything is working or should it have an age after it? The GPS/RTK light is still red on my board.
You are all green and rtk fix you are good to start setting up your first tractor. Use the wizard it makes it so easy. Congrats
