Shapefile import/export
The work around was there when we had VR built in. When we add VR back in again we should consider trying to figure out how to get AgOpenGPS to import and export .shp files.
This would be awesome. I’m working on a project to support AgOpenGPS. My vision is an app and api that AgOpenGps can communicate with and act as a storage facility. If AgOpenGPS can create a shape file should just be able to to sync to server then you can retrieve anywhere. Also opens up the possibility of sharing fields and configuration across systems.
just one idea
Add the latitude and longitude attributes of points A and B to the attributes of the SHP file.
Can I use it with AOG?1123
