Anyone know how to connect the simpleRTK2b to a dsub9 connector on a ntrip modem. True phone with or agopengps just drops down to much.
Greeting
Ray
Greeting
Ray
Super. Thank you !!
I have connected Ntrip modem as TERVUREN showed by the picture.
But i do not recieve any data or fix in AOG.
Do i need to change settings in the ardusimple RTK2b or in the F9p reciever? And what settings must i use in AOG. Like external modem or something like that?
Regards,
Ray
this diagram allows a modem with an integrated ntrip client to send the correction to the f9p via rs232 without going through aog,
so you should not use aog’s nrtip client moreover it is necessary to configure the f9p to receive the correction on uart1.
Is this what you want to do?
attached the f9p configuration file:
RTK2B_FW113_Rover_10Hz-rs232-bt- .txt (20,9 Ko)
then simply connect aog to the f9p which will return a fixed position as for any installation, whether usb, bluetooth or others
you must also check that your modem returns the correction by rs 232 to do so, connect it to your pc by the db9 and use a terminal to read the data transmitted
Works like a charm… put our own build 4G ntrip modem between it and works perfect.
Thanks for the help.
