Hi. When I try to connect to base station, this message appears “Socket exception - Invalid IP:Port”, and there is no RTK, GPS works normally and autosteer too. Before, RTK worked normally, but recently this problem has appeared, it sometimes works and sometimes not. I use simplertk2b board. Port used is 2101 over rtk2go.com. Anyone encountered same problem? Regards.
Can you see the rtk2go list of mount point? Could be a wrong rtk2go IP address
Sorry for not replying too long. That problem occurs from time to time and it resolves on its own way. List of mount points is inaccessible. Can’t be seen and then this message occurs (Invalid IP Port…).
