I am currently working on a project that uses a linear actuator with potentiometer feedback to control the steering on AgOpenGps. It is working well except I get spikes on the movement of the actuator. ie the set point spikes causing the actuator to spike. I have the ADS and the MMA mounted. The pot is 0 to 5 volts. Any advice would be appreciated
Is it the same without MMA?
Yes it is better without the MMA. Are you suggesting that I junk it?
Would a Dogs 2 be better?
As an alternative
Should I connect both the High and Low of the 7 connector to the signal wire of the WAS
thanks for your ideas
