Status not showing satellite info
I have a base station set up using ublox_ZED-F9P that I have verified functions as expected using u-center. I’ve also verified the serial data being sent out on the ttyACM0 port via minicom with all port settings identical.
Everything is green on the services, but nothing is showing up in the status page of the server.
I’m wondering what else I can check to diagnose what the problem is.
Added diagnostic data that seemed relevant to the issue.
Thank you
Jun 28 11:24:29 basegnss systemd[1]: Starting RTKBase Tcp...
Jun 28 11:24:29 basegnss run_cast.sh[464]: stream server start
Jun 28 11:24:29 basegnss run_cast.sh[464]: stream server start error
Jun 28 11:24:29 basegnss systemd[1]: str2str_tcp.service: Succeeded.
Jun 28 11:24:29 basegnss systemd[1]: Started RTKBase Tcp.
Jun 28 11:27:00 basegnss systemd[1]: Starting RTKBase Tcp...
Jun 28 11:27:00 basegnss systemd[1]: Started RTKBase Tcp.
Jun 28 11:27:00 basegnss run_cast.sh[848]: stream server start
Jun 28 11:27:00 basegnss run_cast.sh[848]: 2023/06/28 18:27:19 [CC---] 0 B 0 bps (0) /dev/ttyACM0 (1) 127.0.0.1
Jun 28 11:28:00 basegnss systemd-journald[124]: Suppressed 11 messages from str2str_tcp.service
Jun 28 11:28:00 basegnss run_cast.sh[848]: 2023/06/28 18:28:19 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:28:05 basegnss run_cast.sh[848]: 2023/06/28 18:28:24 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:29:00 basegnss systemd-journald[124]: Suppressed 10 messages from str2str_tcp.service
Jun 28 11:29:00 basegnss run_cast.sh[848]: 2023/06/28 18:29:19 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:29:05 basegnss run_cast.sh[848]: 2023/06/28 18:29:24 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:30:00 basegnss systemd-journald[124]: Suppressed 10 messages from str2str_tcp.service
Jun 28 11:30:00 basegnss run_cast.sh[848]: 2023/06/28 18:30:19 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:30:05 basegnss run_cast.sh[848]: 2023/06/28 18:30:24 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:31:00 basegnss systemd-journald[124]: Suppressed 10 messages from str2str_tcp.service
Jun 28 11:31:00 basegnss run_cast.sh[848]: 2023/06/28 18:31:19 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:31:05 basegnss run_cast.sh[848]: 2023/06/28 18:31:24 [CW---] 49344 B 0 bps (0) /dev/ttyACM0 (1) waiting...
Jun 28 11:31:41 basegnss systemd[1]: Stopping RTKBase Tcp...
Jun 28 11:31:41 basegnss systemd[1]: str2str_tcp.service: Succeeded.
Jun 28 11:31:41 basegnss systemd[1]: Stopped RTKBase Tcp.
Jun 28 11:31:44 basegnss systemd[1]: Starting RTKBase Tcp...
Jun 28 11:31:44 basegnss systemd[1]: Started RTKBase Tcp.
Jun 28 11:31:44 basegnss systemd[1]: str2str_tcp.service: Main process exited, code=exited, status=255/EXCEPTION
Jun 28 11:31:44 basegnss systemd[1]: str2str_tcp.service: Failed with result 'exit-code'.
Jun 28 11:32:14 basegnss systemd[1]: str2str_tcp.service: Service RestartSec=30s expired, scheduling restart.
