Steer and work switch wiring
How do I go about wiring a work switch and a steer switch? I’m thinking pin 8 is for the steer switch and pin 9 is for work switch but how do I wire that or does it come from that pin the go straight to ground?
As it say in the dokumentation, you connect to gnd. Because the pcb have optocouplers that just need a gnd connection to protect and activate/drag low, the correct pin on teensy.
A very simple momentary button works a treat. Connect 1 wire to the steer pin and the other wire to ground
