Did you follow the instructions in Tony’s code about going into the service tool and picking the right mode (usually “P” to forward Panda, iirc) ?
I have now, thank you!
Everything’s working now, had to choose panda mode with the right baud rate
If you want to see how to sniff the CANBUS and find out how to engage with the button of your choice, these videos explain all:
At a 2017 MF 7720 today, found the steering on the lower plug, X888 and the joystick (headland management button) reporting on 0x210[1] & 0x20. Didn’t get the connector number of the port, but it’s the one in the pair next to fender.
Looking to do the same on our 6718s
Do I still need a wheel angle sensor or is it possible to use the existing one fitted to the tractor
If steer ready, you’ll be using the one on CANBUS
Thanks ![]()
