Hello.
We produce Wheel Speed Sensor with Hall sensor inside, Steering mechanism with 27Nm motor with ECM. Connection to steering via UDP (RJ45). It is based on Arduino source code, can be updated by wire according to the AOG version. Shipment from Poland to any EU country. Also there is a warehouse in USA (not fulfilled yet, will be filled after demand).
EUR 1398 ($1509) - ECM+motor+Steering set
EUR 98 ($106) - Wheel angle sensor with bracket and hard metal cap
To complete the kit, you will need:
- tablet
- antenna (either DUAL or single with IMU)
- Ethernet router (in case no Ethernet available on tablet)
