Hello, been building my third autosteer over the past couple of days and i ran into a problem while testing. Im using a step up converter 250W (white pcb) as have i been using for the rest of my tractors. While driving the step up converter just stops working, creating a short between Vin and Vout. I replaced ot with a spear one and the same thing happens.
Should i run this system on 12V or use a different step up module. Can anyone help. Thanks in advance.
I have been running these step up converter i mentioned for a year and a half in my other two tractors, no problems. I don’t understand what can be the problem. This is an older tractor so im using a spare PCB V2 and from it i have been powerint the step up, GND to GND, 12V OUT from the pcb to VIN on the converter, i even put a 3A fuse between the PCB V2 and converter and the fuse didnt blow.
I tried a different converter and it died and also the same problem, short between plus and minus on the input side of the converter. But when cine ting the same wires from the PCB V2 directly to ibt2 it works.
