This is getting embarrassing.
As many of you here will know, I have worked on getting AOG working for probably 18 months and I’ve had a lot of support from you guys fit which I’m grateful.
But right now, I am back to square 1.
Basically autosteer will not work. Everything else works, but autosteer just remains silent.
Last week I had v5 working. I noticed the motor was reversed, so I hit the invert motor button in AOG5 and everything just stopped.
I do not have a BNO085, I have the BNO055, so I assumed this was the problem and reverted back to V4 which supports the 055. Flashed the nano with the autosteer USB ino, fired up AOG, connect the PCB to AOG autosteer and ensured it’s reading the WAS.
Test the Cytron board from the manual buttons and it works, so it has power.
When I connect the PCB to AOG, the LEDs on the nano go crazy, so it’s doing something.
I go into Autosteer, try to manually control the motor…. Nothing. Set up a simulation, no action from the motor.
I’m seriously on the brink of giving up, but before I do is there some small step that I am missing? Is there something I am forgetting to turn on in AOG?
One thing I have noticed is that there is no voltage across the on / off switch. Because I want this always-on, I have just bridged this connection with wire. Should there be voltage across this?
Also there is no voltage across R8 (which is just a wire).
Everything else tests out fine on the multimeter.
Does anyone have any idea what I’m doing wrong, yet again?
