Suggestion-Power unit and implement settings
Would be nice to be able to separate vehicles to their components and have the settings saved.
Ie if you have multiple tractors each would have their own profile, then each implement would have their own profile.
That way you can switch implements between tractors, or different implements on the same tractor and once each one is setup it can just be a pairing menu.
Each tractor and each implement would have its own profile which in theory should never change once setup
Even better to be able to add multiple implements… a tractor pulling a drill pulling a roller for instance.
That’s how it used to be. But that also creates issues because often motor settings are changed for optimizing with different speeds, and for sure the hitch length changes with different implements.
It’s a good thing AOG doesn’t work with databases, it would be a disaster with relations.
