Tablet tip for agopenGps?
Would this tablet from Aliexpress be a good option for agopenGps?
https://www.aliexpress.us/item/3256807930841285.html?spm=a2g0o.cart.0.0.5db67f06qvaLCh&mp=1&pdp_npi=5%40dis!USD!USD%201032.00!USD%20722.40!!USD%20722.40!!!%40210312d517593295410772979e77d4!12000043857614751!ct!US!1688747741!!1!0&_gl=1*1usy0x9*_gcl_aw*R0NMLjE3NTY4MTI3NzMuQ2owS0NRanduOFhGQmhDeEFSSXNBTXlIOEJzWnJyYjlCbktYcjBoMmc0WVIyeFBuTVc5d2tVZ0FudlQ4bnV3cGlDTXFsZzk3ZDdZRXpBZ2FBdWJBRUFMd193Y0I.*_gcl_dc*R0NMLjE3NTUwMTg1NTcuQ2owS0NRand6T3ZFQmhEVkFSSXNBREhmSkpSVHhTWkFWT0xfRGVzdkpOTkNrWG5KYWpLUXdPNUZVQlE1VWljeTVMYzhySzZyQTluZmhnWWFBbkRERUFMd193Y0I.*_gcl_au*NjEwNTgwOTg0LjE3NTM0NjQ2NTA.*_ga*MTUwOTI4MjkxNy4xNzA1MzM3MDk3*_ga_VED1YSGNC7*czE3NTkzMjYzMjckbzk4JGcxJHQxNzU5MzI5NTQxJGo2MCRsMCRoMA..&gatewayAdapt=glo2usa
I’d like to hear everyone’s opinion.
Thank you in advance.
I have the same, its a very good tablet, works great. In my opinion could have had a better cpu but its not as necessary for AOG.
Is it bright enough?
I’d say it is bright “enough”, I didn’t have to use hands to cast a shadow to actually see something. The seller said its 400nits display.
I’d be a bit careful with just 400 nits if you get a lot of direct sunlight in the cab. Personally, I use a Panasonic FZ-G1 for my setup and I think it’s a much better option for this exact reason.
The screen on the FZ-G1 has 800 nits of brightness, which makes a massive difference out in the field. Plus, you can easily get a dedicated anti-reflective foil. CPU in the FZ-G1 is more than powerful enough to run AgOpenGPS smoothly without any hiccups or lag.
