What tablets are people getting nowadays?
The FZ-G1 with rj45 ports are getting hard to find
We haven’t noticed any major issues with purchasing used FZ-G1 MK3 and MK4 units.
We have plenty of them in stock.
As for alternatives, there are Zebra, CF-D1, CF-20, and Dell models.
Personally, I don’t recommend the CF-D1, as they break down frequently.
I don’t recommend the microsoft surface for the same reason…
Dell 2-in-1 such as 5285 5290 7200 etc are quite good. but you’ll ned a USB-Ethernet adapter
Dell 7220 is what I use. If it is important to you it is the oldest Dell rugged that supports windows 11. Usually can be purchased on eBay with warranty for around $300-$350 if you are patient. I have purchase 6 of them so far for me and others and have had good luck. Added a cellular chip on each of them and taped in some LTE antennas into them but is pretty cheap to do.
May not be appropriate place to ask, but how far out is AgOpenWeb from being a daily driver? This would make this discussion much different because it runs on virtually anything.
I have used one of those 2in 1 Dell for 2 and a half year. Bright enough to watch in daylight. Except when sun is low and shine directly across the cabin.
High humidity in springtime have not caused problems even when I let tablet stay in tractor for days.
Have used cigaret lighter usb charger, but remember to get one with high enough watt, else the tablet only run low/half speed.
I switched away from tablets all together and started using single board computers. They seem to be cheaper and more powerful. The downside is you need to get a screen, but there are several on amazon that are plug and play. I have been favoring the GMK Tech G3S. Before all the tarriff stuff you could get them for about $158 USD. I also had really good luck with the Latte Panda Delta 3s. They were about 230.
What displays do you use?
