Hello
how to configure the simpleRTK2B card with the xbee to rs232 adapter to communicate with the tellus go box from kverneland
how to set gps speed in u-center?
Have you managed IT to work f9p with kverneland tellus or tellus pro?
And IT works just out of the box? I mean Basic f9p with xbee converter, wifi for corrections and GPS antenna? This setup should cost me about 300usd
I think you can also use the Gpsout program thats already in the new agopengps version. Choose serialport and messages. Select hz and insert usb to serial adapter and you also ready to go.
I had already sold my setup for small Kubota, so I’m fresh in the topic ![]()
Yes it works out of the box this way. Verified on 2 tractors so far ![]()
If you don’t need RTK Fix on it then it could work on its own.
