how u get the Google Earth underlay?
very good explanation, thanks for sharing it
Hello, is there a way to create tramlines in different directions? Like AB Lines/curves. I marked it as type 1, type 2 and type 3 in the picture. In this example type 1 is part of the boundary curve.
I had limited success with generating tramlines based on different AB lines. You can initialy generate trams as requred the normal way. Than open the tramline file with an external texteditor and copy the correct parts of the text. Thereafter regenerate trams with the new AB line and paste the previous text on the end of the new file.
Be aware that every press on the tramlinemenue button will remove all existing trams and regenerate just the last selected AB Line! Make a backup of the self edited file, you will need it!
A improved tram generator, based on the saved ABlines, would be a nice feature.
Definitely!
I will test your approach. Still better than not being able to use the function at all.
In mid-July a version with Tramlines generator was posted in the German telegram group.
