I’m trying to get section control working using AOG 6.6.2 ,machine udp V5 , with a Nano !
Section 1-3 ( D4-D6 ) works great but I’m trying to get 5 sections working, I’ve been adjusting the ino code, but nothing changes. D7-D9 are constantly powered . I got something messed up with the sketch in these pictures
That is the standard pinout .
You’ll notice that section 8 and 9 are wrong that was my fault for putting the wrong motor to the wrong pin on the relay board and too lazy to swap wires i just swapped the pin setup in machine module settings
The teensy autosteer code has some commented out code to control sections if I remember correctly.
From what I remember it was easy to set one pin to react according the work status for one of my projects.
Or you are talking about the Nano code not working on a Teensy?
