Any ideas if this is settings error? It closes AOG in middle of field and makes you restart it randomly.
Its a bug, but where. What are the Details.
It only stays on screen for a short time then disappears I will try to get info. I do have vehicle profiles saved from previous versions I have been using, I used default on a previous job and it didn’t do this. Not sure if that’s a direction of the bug but only thing I can think of.
Probably a corrupted settings file from shutting off the tablet with a field / vehicle open, or something.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
OpenTK.Graphics.GraphicsContextException: Failed to make context 65537 current. Error: -1073283041
at OpenTK.Platform.Windows.WinGLContext.MakeCurrent(IWindowInfo window)
at AgOpenGPS.FormGPS.UpdateFixPosition()
at AgOpenGPS.CSim.DoSimTick(Double _st)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.9241.0 built by: NET481REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
AgOpenGPS
Assembly Version: 6.3.3.0
Win32 Version: 6.3.3
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/AgOpenGPS.exe
Win32 Version: 4.8.9195.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.9236.0 built by: NET481REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.9037.0 built by: NET481REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK.GLControl
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/OpenTK.GLControl.DLL
OpenTK
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/OpenTK.DLL
RepeatButtonControl
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/RepeatButtonControl.DLL
Microsoft.GeneratedCode
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Control.Draggable
Assembly Version: 1.0.7235.37687
Win32 Version: 1.0.7235.37687
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/Control.Draggable.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Keypad
Assembly Version: 5.2.3.0
Win32 Version: 5.2.10.0
CodeBase: file:///C:/Users/ToughPad1/OneDrive/AgOpenGPS/AgOpenGPS%20original/LATEST%20VERSION%20AOG/AgOpenGPS_v63/AgOpenGPS_v63/Keypad.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Load Boundary LineSystem.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at AgOpenGPS.CBoundary.BuildTurnLines()
at AgOpenGPS.FormGPS.FileOpenField(String _openType) - 9/11/2023 6:31:34 PM
at AgOpenGPS.FormGPS.FileOpenField(String _openType) - 9/12/2023 7:37:33 PM
at AgOpenGPS.FormGPS.FileOpenField(String _openType) - 9/27/2023 5:19:44 PM
Load Headland LoopSystem.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at AgOpenGPS.FormGPS.FileOpenField(String _openType) - 11/1/2024 10:45:13 PM
at AgOpenGPS.FormGPS.FileOpenField(String _openType) - 11/1/2024 10:47:52 PM
