It’s harvest time and I need a way to get gps just for straight lines, no turning at ends of feilds. Ive been researching this program alot. I have an ez steer i can use and a laptop that will run aog. Just need to know everything else I need. It is for use in a 9250 case tractor that will pull the graincart. Thanks
PCB4.1 board, pretty much. Teensy 4.1, BNO085 IMU, ZED-F9P Micro or Standard, depending on which board you go for.
So all I need is a rtx reviever board that has a dish plug in that plugs into laptop.
Oh,and also how do I hook up the ez steer motor and where.
Where you from?
Vauxhall Alberta
