Use guidance systems that accept nmea 0183 messages in rtk mode with f9p simplertk2b
it is necessary to configure the xbee and uart2 module to 115200
you can use the attached configuration file for the fw 1.13
RTK2B_FW113_Rover_10Hz-rs232-bt- .txt (20,9 Ko)
you can use the attached configuration file for the fw 1.30
TERV-RTK2B_FW130_Rover_10Hz-uart1-uart2-gga vtg.txt (25,0 Ko)
or:
TERV-RTK2B_FW130_Rover_10Hz-uart1-2-gga vtg-zda.txt (25,0 Ko)
Yes I believe so. This is just the speed for bluetooth.
UART1 will have to be set to whatever speed the guidance system wants.
I just wish someone added tilt compensation to the above setup. Could replace our oldish (2017) AGCO branded Topcon AGI-4 that only supports GPS and Glonass. A couple of small fields are surrounded by forest and AGI4 loses RTK fix if the birds are not at their average or best positions.
@nut and others have been working on it.
